These should be the connectors you are looking for. The first one is the DPFE connector with a reference power(brown with white stripe) Signal ground(orange wire) and signal feed(brown light green stripe) to the ECM.
The second one for the solenoid isn't super critical as it's only a white wire with red stripe for power and the violet as an ECM switched ground.
Jul 24, 2020 at 10:32 AM
