I have recently thrown out the factory 4.3L Vortec out of my truck it is the K1500 model and replaced it with the 5.7L Vortec out of my 1999 Cadillac Escalade. Engine has previously been slightly bored and has RV/towing cam all done when I rebuilt it in the Escalade. During the swap I deleted A/C (stupid move on my part) and got rid of the fuel injection along with pretty much everything that was computer controlled and replaced it with a Jegs dual plane intake and a 750cfm Edelbrock along with a Accel super-coil HEI distributor with MSD cap and rotor. Before the swap. obviously, it had an EGR system. Now, since intake is not EGR compatible, I just capped off the hole on the exhaust manifold. The engine runs excellent and has no problem lighting up the 35/12.50/R18 procomp mud terrains and gets better fuel mileage than any full size 4x4 I have ever owned. My question is, if not running the EGR system will eventually cause failure? Also a lot of guys talked about the melonized gear on distributor and having to use only that but original distributor did not have a melonized gear, but replacement I put in last year did. Accel HEI does not. Will this be an issue? Any input at all will be helpful because it is my daily driver but also my constant project so I am always looking for the next idea.
1997 Cheyenne 4x4.
5.7 SBC vortec heads 750 Edelbrock.
True dual exhaust, hollowed cats, w/Flowmaster dual-in/dual-in muffler.
4L60E with no computer control what-so-ever.
NP241 .
3" torsion key lift.
35-12.50-R18 procomp mud terrains.
1997 Cheyenne 4x4.
NP241 .
Sep 26, 2017 at 3:03 AM
