EGR Poblem
1997 TOYOTA RAV4
202,000 MILES
MIKEMAC777
  • 5 POSTS
The hose on the EGR valve keep blowing off. i replaced the EGR valve but it still does it.
May 3, 2013 at 5:34 AM
KHLOW2008
  • 41,814 POSTS
Check the passage under the valve for clogging. This would result in excessive back pressure when EGR valve opens.
May 3, 2013 at 6:01 AM
MIKEMAC777
  • 5 POSTS
Ok here is the whole story.
Hose keeps blowing off the bottom of the egr valve. It first started when the port of vacuum got hot and melted so I replaced it then I replaced the vacuum modulator because the hose kept blowing off it. Now the hose is blowing off the EGR valve so I replaced it but it is still blowing off.
May 3, 2013 at 6:45 AM
KHLOW2008
  • 41,814 POSTS
Check for clogging of the passages.
May 3, 2013 at 8:42 AM
