EGR pipe assembly discontinued
1989 BUICK REGAL
55,900 MILES • 2.8L • 6 CYL • 2WD • AUTOMATIC
COOLOLDS85
  • 173 POSTS
EGR pipe assembly discontinued. Part original part broke in half what do i do?
Part number is discontinued 14102605.
Bought wrong part 10051561 off eBay that did not fit my vehicle and pipe could not pull out further.
Do not know if anyone can fabricate me a new pipe because my old one is cracked and is apart.
Apr 29, 2018 at 9:01 AM
CJ MEDEVAC
  • 11,004 POSTS
Do any of these look right?
https://www.amazon.com/Recirculation-Replacement-Chevrolet-Oldsmobile-24508969/dp/B016PR1JQK
The Medic
Apr 29, 2018 at 12:05 PM
COOLOLDS85
  • 173 POSTS
Nope.
Apr 29, 2018 at 1:26 PM
CJ MEDEVAC
  • 11,004 POSTS
I found this!
https://www.ebay.com/p/NOS-GM-OEM-EGR-System-Tube-and-Valve-Assembly-10100090-F-1992-1993-V6-Chevy/654837495?iid=222678777974&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D50544%26meid%3Daba847eafaff4c1b91193f8e8f96481b%26pid%3D100011%26rk%3D3%26rkt%3D5%26sd%3D191633140698%26itm%3D222678777974&_trksid=p2047675.c100011.m1850
Found this too!
https://www.ebay.com/itm/Genuine-Tube-10051561/253512895753?epid=671281988&hash=item3b068bcd09:g:4AIAAOSwxwRatBDv
Whoa! Those are like one and a half times of what I paid for my Army Jeep!
I do not do the pricing, unless you can replicate something to take its place, you may still be able to find one in the salvage yard.
I spent about an hour surfing for another/ better deal. No luck elsewhere.
The Medic
Apr 29, 2018 at 7:38 PM
COOLOLDS85
  • 173 POSTS
Part 10051561 does not fit my car.
Apr 30, 2018 at 7:11 AM
CJ MEDEVAC
  • 11,004 POSTS
Okay.
What about the one in the first link I posted?
The Medic
Apr 30, 2018 at 4:05 PM
COOLOLDS85
  • 173 POSTS
That would not fit because it has a different adapter end that connects to the EGR control valve. Here is a picture.
Apr 30, 2018 at 6:52 PM
CJ MEDEVAC
  • 11,004 POSTS
How about a picture of what you have?
The Medic
Apr 30, 2018 at 7:14 PM
COOLOLDS85
  • 173 POSTS
One on the right is wrong part I sent back. One on the left is the original I need that will fit with being the right length.
Apr 30, 2018 at 9:19 PM
COOLOLDS85
  • 173 POSTS
I apologize loaded the same pictures three times.
Apr 30, 2018 at 9:23 PM
Good morning.
Try this place. Call them to confirm. Looks like the correct part you need.
https://www.corvetteparts4less.com/a/Chevrolet__/59805853__6397872/EMISSION-SYSTEM-EMISSION-COMPONENTS/CN87650.html
May 2, 2018 at 4:35 AM
COOLOLDS85
  • 173 POSTS
Called them yesterday. None of the dealerships all over the USA have the part or know anyone that has the part. It is a really hard to find part since a lot were sold.
May 2, 2018 at 5:31 AM
Okay, sorry.
Did you ask them if anyone has NOS or new old stock? A lot of dealers have that but will not list the part as stocked.
May 2, 2018 at 5:33 AM
COOLOLDS85
  • 173 POSTS
Yep. Tried that too. And now people are telling me it will cost an arm and leg to have one made. I guess if I cannot find one my last route is finding one at the salvage yard.
May 2, 2018 at 6:48 AM
Okay.
Here is a suggestion: Try to find a line with the bendable center like your. It may have a different end but you can use the bendable portion. Then get a line with the correct needs. Then you can have some one cut and weld the lines to make what you have. It will cost you two lines and someone to cut and weld but at least it will work.
May 2, 2018 at 7:19 AM
COOLOLDS85
  • 173 POSTS
Do you think it would save me a lot more money than having someone fabricate it? I mean I do not even have an idea what something like that to fabricate would cost.
May 2, 2018 at 7:32 AM
About $200.00 to $250.00.
May 2, 2018 at 10:01 AM
COOLOLDS85
  • 173 POSTS
To fabricate a pipe or to do it the cheap way?
May 2, 2018 at 1:31 PM
To fabricate the pipe to your specs with your ends of the line provided.
May 2, 2018 at 2:17 PM
CJ MEDEVAC
  • 11,004 POSTS
Looking at your pictures (way above).
The short one on the right.
Is it in the "relaxed accordion" state/ position.
Will it "stretch out" to be as long as the one on the left.
Thought maybe the correlations were stacked tight as with a bendable drinking straw.
The Medic
May 2, 2018 at 3:37 PM
COOLOLDS85
  • 173 POSTS
Yeah, I tried bending it but could not really extended it any further because I did not want to break it. I tried every position with the one that did not fit.
May 2, 2018 at 4:02 PM
CJ MEDEVAC
  • 11,004 POSTS
Answer above, "correlations" was supposed to be "corrugations".
Do the corrugations look like they are close together and they would stretch out to look like the original?
If they are close together and look like the would stretch on out.
My approach might be to drop two sacrificial bolts through the flange and then grab the bolts threads only, in a vise.
I would take a big crescent wrench and snug it up on the tube just below (and against) the nut on the other end of the tube.
If you could then pull it by the crescent wrench.
Maybe a slow pull, by cutting a block of wood to fit from the top of the vise and under the wrench might give you some "prying" leverage. If needed stack more goodies on to of the block of wood to continue the stretching process.
Just a thought, throwing some straws, I cannt see the actual problem from here!
Keep us updated.
The Medic
May 3, 2018 at 4:15 PM
