I don't feel you should have power from the sensor inputs. Any input sensor signal is to provide information to the powertrain control module so it can output information such as air/fuel mixture or fuel injection as examples to other sensors.
With the sensor disconnected, that shouldn't be. That is power back to the PCM. As far as pin 6 (signal ground) that is an isolated ground provided via the PCM, so that is normal.
Your reference voltages seem to be correct. When you checked pin 6, was there any resistance to ground? I'm wondering if the PCM ground may be weak.
May 7, 2023 at 9:25 PM
