the other night driving home on the highway it shutoff and would not start. Once I got the car home I found that EFI fuse was blown. When I go to replace the fuse it blows before I can even get it plugged in and there is no key in the ignition. I then proceeded to check wiring for possible short and could not find anything. I then pulled the EFI relay and tried plugging in fuse and it did not blow. I also unplugged all the injectors plugged relay back in then tried to put fuse in and it blew. So is it a bad relay that is causing this?
Apr 6, 2017 at 4:12 PM
