ECU replacement
2001 MERCEDES BENZ S600
170 MILES • 5.8L • V12 • 2WD • AUTOMATIC
RAMZITH1
  • 70 POSTS
My car listed above (W220). Can I replace the defected ECU of my car A1371530179 with a newer version ECU no A1371530879? thanks
RAMZI
Sep 9, 2020 at 11:19 PM
Good morning,
Where did you get those numbers for the ECM? I do not see those numbers listed from Benz.
Sep 10, 2020 at 4:49 AM
RAMZITH1
  • 70 POSTS
Good day,
Got them from the stickers on the ECU it self , see pictures.
First picture is from my car and the rest is from eBay.
thanks,
RAMZI
Sep 10, 2020 at 5:48 AM
Okay, that is the wrong unit for your car.
I attached the correct unit for you.
https://www.ebay.com/itm/B-19-MERCEDES-BENZ-CLK-ECU-ENGINE-CONTROL-MODULE-0255458932-/172887378281
Sep 10, 2020 at 8:15 AM
RAMZITH1
  • 70 POSTS
Hello Roy,
My car is 2001 Mercedes Benz S600 V12 5.8L, are you sure of this unit?
Attached is the information of my car.
Please reply me as soon as possible.
Thanks,
RAMZI
Sep 10, 2020 at 9:02 AM
RAMZITH1
  • 70 POSTS
The vin is:
WDB2201781A238906
Sep 10, 2020 at 9:06 AM
I just checked as this is not a USA VIN number.
The ECM you chose has the same numbers as the one you removed, so it should work once it is programmed to your car.
Sep 11, 2020 at 3:39 AM
RAMZITH1
  • 70 POSTS
Thanks, will do check and let you know as soon as I get the item on hand by next week hopefully. thanks once again.
RAMZI
Sep 11, 2020 at 6:36 AM
You are welcome.
Always glad to help.
Sep 11, 2020 at 6:37 AM
