ECU/PCM location
2009 KIA RONDO
144,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BARBYMAC88
Does anyone know the location of the ECU/PCM on the vehicle listed above LX? If possible could you provide a diagram? Thank you!
Mar 16, 2021 at 5:28 AM
Good morning,
The ECM is by the master cylinder. I attached the procedure and a picture for the repair.
Replacement
1. Turn ignition switch off.
2. Disconnect the battery (-) cable from the battery.
3. Remove the PCM cover and disconnect the PCM connector(s) (A).
4. Unscrew the PCM mounting bolts (B) and remove the PCM (C) from the air cleaner assembly.
5. Install a new PCM.
PCM mounting bolts:
9.8 - 11.8 N.m (1.0 - 1.2 kgf.m, 7.2 - 8.7 lb-ft)
Mar 16, 2021 at 8:13 AM
BARBYMAC88
Thank you!! Found it!!
Mar 17, 2021 at 4:26 PM
You are welcome.
Always glad to help.
Mar 17, 2021 at 4:30 PM
