ECU no response to OBDII adapter
2016 TOYOTA RACTIS
100,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
CHEUNG TUNGKWA
the OBDII adapter can not communicate with the ECU, so it cannot check out the trouble code.
Mar 6, 2018 at 7:53 AM
It sounds like you have an OBD fuse that is out 7.5 amp. Here is a guide to help you test the fuse once you find it from the fuse panel diagrams (Below).
Here are the wiring diagrams for the OBD2 data link connector and the fuse panel locations and identifications.
Check out the diagrams (below).
Mar 7, 2018 at 2:08 PM
