Good afternoon,
It is behind the glove box. I attached the procedure and a picture for you.
Why are you replacing it?
How to Remove the ECM/PCM for Testing
If the inspection for a trouble code requires voltage or resistance checks at the ECM/PCM connectors, remove the ECM/PCM and test it:
1. Remove glove box.
2. Disconnect the gray 20P ECM/PCM wire harness connector, and remove it from the ECM/PCM mounting bracket. Disconnect the 7P mode control motor connector. Remove PGM-FI main relay 2 (A). Remove the ECM/PCM mounting bolt (B) and the bracket.
3. Remove the nuts, then remove the ECM/PCM (C).
4. Install the ECM/PCM in the reverse order of removal.
Dec 30, 2020 at 11:12 AM
(Merged)
