changed my battery I must have turned ignition switch on. engine did not start again.
checked the ECU, LED self diagnosis system.
no flash. Book (Haynes) indicates inspect number 5 fuse.
There is a caution elsewhere in the book to prevent damage to the ECU, the ignition switch must remain off when disconnecting or connecting power.
I cannot locate fuse number five. I have checked both fuse boxes under hood and inside. they do not identify a number 5 fuse.
any ideas? Thanks
any ideas? Thanks
Mar 10, 2018 at 12:08 AM
