That will make it tough to repair that ECU as the components are very small. There are places that will rebuild them but you could likely get a used unit reprogrammed to fit your Jeep for less. I normally reserve a rebuild for ones that are either super expensive or no spares exist. The reason there is no com with that ECU is likely because the 12 volts is there to power it but most of the internals operate off the 5 volt buss along with the sensors. It's also likely that the 12 volt feed has a similar issue of corroded parts on the board.
If you would like to see the way these boards can be tested and repaired take a look at Maic Salazar Diagnostics and L1 Automotive Training both have a few videos on tracing the faults and repairing at board level, might give you an idea of a way to proceed.
Apr 28, 2021 at 3:27 PM
