The car listed above is a GT, with a 5-speed manual. On startup, coolant temperature reading on OBD1 scan tool starts near ambient temperature, rises normally until it reaches 122 or 123 degrees F, then immediately spikes to 258 degrees. The sensor was tested and resistance readings are nearly identical to factory service manual chart at various temperatures - steady temperature increase mirrored by steadily declining resistance. Once the temperature spikes, the cooling fan comes on (ECM response to high reading) and the temperature continues to rise (according to the scan tool) at a normal rate, topping out at 304 degrees F after about 20 minutes of run time. Since the ECM does not display readings between 123 and 258, is this indicative of a failing ECM?
Jun 2, 2021 at 10:39 AM
