Good morning,
If the check engine light comes on with the key on and the fuel pump runs for 2 seconds, then the ECM is working and may not be the issue.
Does the engine run? If it does and cannot communicate, it may be the scan tool you are using. Try it on another car to see if it works.
As far as testing, special equipment is required for the actual testing to see if it is good. You could remove it and send it out and have it checked.
What is the exact issue with the car?
Oct 10, 2021 at 5:27 AM
