The ECM fuse powers a few different things. First, all the fuel injectors receive power from it. Also, the crankshaft position sensor receives an ignition feed. Last, the ignition coil driver as well.
I attached the schematics below for the powertrain management circuits. I highlighted all the wires related to the fuse you mentioned. Before going crazy, check to make sure the pins where the fuse plugs in are in good condition, not bent, pushed in, or corroded. A poor connection creates heat which can cause the fuse to fail.
Next, look at the schematic. It indicates where the wires go. Check for a short or damage to any of the circuits powered by the fuse.
I suspect that we have a bad connection at some point causing heat to build up until the fuse fails. If it were a dead short, that would blow the fuse right away, so make sure to check all connectors as well as wiring conditions and for corrosion. Here is a link you may find helpful:
I'm sitting here thinking. Make sure the wiring at the crankshaft position sensor isn't rubbing the crank pulley. It's just a theory at this point.
Let me know what you find or if you have questions.
See pics below. Note: The schematics were four pages long. I had to cut each pic in half to make them readable for you. I did overlap them so you can follow from one to the next.
Oct 26, 2021 at 8:54 PM
