My car has been nothing but problems here and there. To make it short, I recently got the engine light on and I went to a mechanic to fix things. He changed a few sensors (image attached below) that were causing issues and still, the check engine light remained on. Then, he proceeded to saying that the computer or ECM was failing and needed replacement. He has a friend who has the ECM and the necessary equipment to fix the problem but he is not reliable, as we have tried many times but he never shows up. Anyway, before I go and spend thousands of dollars trying to fix issues here and there, I wanted to consult with another mechanic and get a second opinion on whether the ECM is at fault or might be something more severe. Also, from the attached image, the red code is new. I had not seen it before changing the other sensors. Thank you!
Mar 2, 2021 at 8:35 AM
