3.3 93 with 97K
When hot and parked, after short time wont start, turns over, found it had no spark. Waited 30 min, started perfectly.Does not do this every day. Changed spark plugs, cam sensor, coil, crank sensor. Now its worse than ever, if I get it started it is running on 3 or 4 badly, try feathering accel and it back fires with big flat spot. Starts with a miss, does not develop, sound like it is flooded or has 2 wet plugs, but if I can keep it running , nothing clears out. Feed the accel gently and it gets to 1500rpm with the missing and occasional backfire through inlet, like timing was out and dead plugs. Next change I have a fuel filter. Where should I be looking? Before I changed the sensors at least it started and ran fine, once it did start. Now very depressing. Should I just go fishing or start drinking? Or both?
May 19, 2007 at 11:03 AM
