1995 Eagle Vision engine will not start
1995 EAGLE VISION
180,000 MILES • 6 CYL • FWD • AUTOMATIC
J.SCHMITZ
  • 8 POSTS
we cannot hear the fuel pump kick in when we turn on the key on . we put a new fuel pump in but it still did not turn on. it has been hard to start also
Feb 9, 2009 at 9:30 PM
Check fuse no.18 10amp and test the fuel pump relay
Feb 9, 2009 at 9:47 PM
J.SCHMITZ
  • 8 POSTS
i replaced the ten amp fuse no. 18 and the fuel pump relay. when i turned the key on, i do not hear the fuel pump kick in.
Feb 12, 2009 at 7:32 PM
Direct battery power to the dark green wire on the fuel pump connector-if it comes on test the ASD relay
Also check fuse A 20amp in power distribution center
Feb 13, 2009 at 10:08 AM
J.SCHMITZ
  • 8 POSTS
the test light did not come on from the negative post in the battery to the green wire. it also is a 94', not a 95'.i checked the fuse and i it looked good.
Feb 15, 2009 at 4:26 PM
I meant power the fuel pump from the battery positive post to the green wire at the connector and see if it comes on
Feb 15, 2009 at 7:37 PM
J.SCHMITZ
  • 8 POSTS
i un pluged the the connector at the fuel pump and hook a wire from the battery to the place where the green wire would go .no luck the pump did not run .i also tried with the connector pluged . no luck either
Feb 16, 2009 at 2:08 PM
J.SCHMITZ
  • 8 POSTS
i ran jumper cables back to the fuel pump. i unpluged the connector then ran jumper wires to the puup the green one to the + the black to the - then the pump ran
Feb 16, 2009 at 2:42 PM
Check the ground circuit if okay replace the fuel pump.
The green wire is the power to the fuel pump
Feb 16, 2009 at 2:43 PM
J.SCHMITZ
  • 8 POSTS
with the key on there is no power at the green wire at the connector to the fuel pump. where does the other end go to?
Feb 16, 2009 at 3:42 PM
What your doing is bypassing the fuel pump circuit and directing power from the battery if its not coming on you have a defective fuel pump. Even if the key is on you should have power to it before the relay de-energize
Feb 16, 2009 at 4:23 PM
J.SCHMITZ
  • 8 POSTS
there is no power to the green wire when the key is on.ichecked it with a test light.
Feb 18, 2009 at 4:11 PM
Get a wire hook one end to the battery positive terminal and the other end to the green wire at the fuel pump connector-if the pump is good it should come on-if not check the ground if okay -replace the fuel pump.
Feb 18, 2009 at 4:44 PM
J.SCHMITZ
  • 8 POSTS
ii ran a wirre from the battery +side to the green wire .the fuel pump ran . now what?
Feb 19, 2009 at 4:00 PM
Check fuse no.18 10amp and test the fuel pump relay-You did this and its okay-
Now you need to test the computer controlled of the fuel pump relay-
Feb 19, 2009 at 6:43 PM
