speedometer and fuel gauge
1993 EAGLE VISION
MARIA1KINCAID
Electrical problem 6 cyl Two Wheel Drive Automatic 105000 miles
What can i do to make my speedometer and fuel gauge work again? i have changed the fuses and it still doesn't work.
Apr 4, 2010 at 11:40 AM
I would remove the instrument cluster and unplug the electrical connector and the rear of the cluster. Also check for corrosion.
Please run this test and get back to us.
Jan 29, 2018 at 7:06 PM
MARIA1KINCAID
That didn't work so I took the cluster and had it checked it was bad so I got a rebuilt unit now everything works, though you should know so it helps others.
Jan 29, 2018 at 7:08 PM
