Suggestions For Head Gasket Problems 92 Eagle Talon TSI AWD
1992 EAGLE TALON
JOSHWITDATALON
  • 15 POSTS
I have a 92 eagle talon. its turboed and all wheel drive. it has a 2.0 straight four cylinder engine in it with about 1455,000 miles on it and i keep on losing all of my oil and i end up finding it on my drive way. from what i can tell from having it up on a lift, i beleive it is the head gasket that is blown. (i hear that talons are famous for blowing the head gaskets from alot of people.) But anyways i suppose i will have to replace the head gasket, but here is the part i dont get. from reading articles on the web and talking to other D.S.M. owners they say that if i use just a regular head gasket again that i should be ready to redo it all in 30,000 miles or so, they all recomened using a copper head gasket and the copper gaskets all the way around the engine as well. Is goin with a copper head gasket the right solution to solve my problem for a more than average length of time? Or are talons famous for leaking the oil from anywhere else like the turbo that i could go and re check to make shure? Thak you very much for your helpful input!!!
Mar 28, 2007 at 1:15 AM
KIN CHAN
  • 453 POSTS
just kidding...never heard of such things....u bellieve exactly these info over the web???...geeee...i wander if these people make a living working on cars only?...OEM gasketis fine...oil leak must be sure b4 pulling head...i haven't heard of or seen oil leak fr gasket on mitsubishi yet ( i work on cars for a living only) ...msg me if u need more info....30K change head gasket..thats a myth and fairy tales...heh heh heh haw haw haw haw ...heeeeee hawwwww
Mar 28, 2007 at 7:37 AM
KAYJEB
hi, i saw your question just after i posted mine, I'm going through the same problem, but wasn't told anything bout needed copper head gaskets. and so far I haven't found mine leaking anywhere else. (non-turbo) hope this helps get a gauge on the prob, common yet a OEM part will likely be all it takes to get your leak stopped
Jul 21, 2007 at 11:22 AM
KIN CHAN
  • 453 POSTS
u should apply to be a moderator here...make more sense than a lot of mechanic i encounter in real life...
Jul 21, 2007 at 8:36 PM
