oil leak
EAGLE TALON
RIK_JAMES
i have a 1992 Eagle Talon Tsi with 100,000miles on it and just yesterday it started to puff blue smoke only when i accelerated i discovered oil leaking by the injectors could that be the problem? i also checked the PCV valve and i changed the valve cover gasket but it still didn't fix the oil leaking by the fuel injectors
May 31, 2006 at 2:29 AM
It sounds like you may have worn piston rings. Perform a leak down test to determine if you have excessive blow by (piston ring wear) :(
Sep 12, 2006 at 6:30 PM
