1997 Eagle Talon Starter relay
1997 EAGLE TALON
97,000 MILES • 4 CYL • FWD • AUTOMATIC
DRUMMEL
Starting this car with the key is very spuratic. If it doesn't start with the key, you can leave the key on and jump the starter at the terminals and it will start every time. Sometimes it does it when it's hot, or sometimes it does it when it's cold. We replaced the starter/soleliod, cranks faster, but still has the same symptoms. Could this be the relay? Someone told us it was maybe the ignition module, but could not find this in the chiltons manual. Please, HELP! Thanks, Brian
Apr 18, 2009 at 4:37 PM
CARADIODOC
  • 34,306 POSTS
No starter relay on this car. Start by checking the ignition switch for burned terminals or a melted connector.
caradiodoc
Apr 29, 2009 at 1:22 AM
