Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Eagle
Talon
Engine
Piston
Rod
Bearing
1995 Eagle Talon rod bearings
1995 EAGLE TALON
13,000 MILES • 4 CYL • AWD • MANUAL
JCAND24
MEMBER
1 POST
FOLLOW
are the rod bearings for a non-turbo talon the same as a talon with a turbo?
Mar 20, 2008 at 4:58 PM
CERTIFIED EXPERT
What are you trying to do here swap bearings bad idea-mike the crank or use the plastigauge and select the correct undersize bearings.
Mar 20, 2008 at 5:28 PM
