1995 Eagle Talon hi
1995 EAGLE TALON
JERRYWARE
1995 Eagle Talon 4 cyl Front Wheel Drive Manual 140k miles
[img:e23047b293]http://www.2carpros.com/forum/automotive_pictures/477608_snc002651_2_1.jpg[/img:e23047b293]
HI okay i have a prob with my car...it wont start some times it will start and it will run for 10 to 20 mins then it when die then wont start back up but when i wait for a while it starts back up then 10 to 20 min it dies again n wont start and while the car is on the idle is going to low then it will stall then n wont trun back on...people told me it could be the coil pack got a new one still did it then i got a fuel pump and got a fuel filter still did it...then somone told me it could be the sensor i got new camshatf sensor new crankshatf sensor and got a new TPS sensor n it stills run then 10 to 20 it dies n wont start back up again..can u plz tell me whats going on with my car plz thank you
Feb 6, 2010 at 7:07 PM
M_FOLZ21
have you changed the stock radio to and aftermarket radio? if so its an issue with antitheft and you need to use the original key to fix that due to the keys having a chip in them. otherwise i would check the auto shutdown relay. its the 3rd relay from the door by the drivers side firewall.
Feb 21, 2010 at 5:51 PM
JERRYWARE123
[quote:7557185397="m_folz21"]have you changed the stock radio to and aftermarket radio? if so its an issue with antitheft and you need to use the original key to fix that due to the keys having a chip in them. otherwise i would check the auto shutdown relay. its the 3rd relay from the door by the drivers side firewall.[/quote:7557185397]
ya theres a aftermarket radio in there...so what do i need to chang to make it the anititheft to come off n what u mean the original key? do you mean the key to start the car if so ya its the original key to it...and u said it might be the auto shutdown relay is it under the hood by the firewall on the driver u said its the 3rd one n can u send me a pic of the relay plz thank you
Feb 21, 2010 at 7:35 PM
