Engine Mechanical problem
1995 Eagle Talon 4 cyl Front Wheel Drive Manual
Hello, my name is marc and i have an eagle talon tsi with a 4g63t in it and i have a question. The car will start up fine and will run fine, but after a minute or so it would bog down and lose power even while sitting in the garage and yuo rev it from the engine it wont accelerate. i checked the timing, replaced the spark plugs and gapped them right, checked the o2 sensor and is good, changed the fuel pump, did a fuel pressure test and it was good. The only other 3 things i could imagine it being is either the fuel pressure regulator, throttle position sensor or a maf sensor but i want a mechanics opinion on what the major thing is wrong with it or if i am missing anything.
Aug 19, 2009 at 5:16 PM
