1995 eagle talon drivetrain
1995 EAGLE TALON
CHUCKALUCK
I drive a 1995 Eagle Talon tsi with a five (5) speed manual transmission. When I drive at speeds of 70 mph I sometimes experiance a vibration as if the wheels are out of alignment. I have been told that the carrier for the drive shaft is loose. What does that require to be repaired?
This car is a 1995 Eagle Talon tsi
It has 115,000 miles and is a 5 speed manual.
Sep 23, 2007 at 12:12 AM
ARCHAMETES
I have a 95 TSi AWD ATX and my rear carrier/ differential just locked up coming down the road so be careful. I have been told by the dealership that the LSD in the rear carrier and the pinion and ring gears will shatter if not 100% correctly lubricated at all times. Check your fluid level to make sure and if in doubt as to when it was last changed drain it and refill it. Keep me posted as to if your problem gets worse and if I get mine done I''ll let you know exactly what's involved.
Thanks, Mike
Nov 17, 2007 at 11:04 AM
