1991 Eagle Talon oil pressure
1991 EAGLE TALON
188,000 MILES • 6 CYL • AWD • MANUAL
BRENTB
I installed a oil pressure gauge and sender. when im idling it shows my oil pressure is 100 psi and when i touch the gas is maxes out. i didnt do anything else except remove the old sender and installed the new one.
Thanks brent
Nov 5, 2008 at 12:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Make sure all of your wires are hooked up properly and none are loose or faulty. If all is good here, try disconnecting your ground cable for 5 minutes to see if the computer needs to be reset for the new sender to work properly.
Nov 5, 2008 at 1:01 AM
