1991 Eagle Talon baterry charge fails
1991 EAGLE TALON
SPORTS-CAR-NEWB
Electrical problem
1991 Eagle Talon 4 cyl Front Wheel Drive Manual 190k miles
I got this 91 eagle talon with a mitsubishi engine dohc 2000 and I just replaced the manual trany and a interstate battery then my alternator went bad so I replaced that and after only 3 days of having the rebuilt alternator in I have starting problems, I hook up a battery charger and it starts and runs but after I turn it off the battery is dead again. I am sorry for no donations today I dont have a credit card nor any money I would however try to donate if I can later on
Oct 8, 2009 at 11:56 PM
JEEPFAN
  • 135 POSTS
check to see if there is a draw on the system heres how you do it.....
get a test light and disconnect the negative battery cable connect the test light to the cable and put the probe part of the light on the battery post if the light comes on then there is a draw start pulling fuses till the light goes out to find what component is draining the battery
Oct 9, 2009 at 12:38 AM
