1994 Eagle Summit I am stumped!
1994 EAGLE SUMMIT
150,000 MILES • 4 CYL • FWD • MANUAL
CONFUZED
The car suddenly stalls out after the engine is warmed up, usually. It doesn't matter if the tank if full or almost empty. It does it when i am at cruising speed or idling at a stop sign, but mostly when i am stopped. It is not throwing any codes. It is the 1.5L engine. I have replaced fuel pump, fuel filter, O2 sensors, distributor, cap and rotor, plugs, plug wires, and have taken it to two different dealerships and they can't figure it out either. When it stalls out it is getting gas and spark. It will usually start after it sits for a bit but then does it all over again the next day. Please help!
May 13, 2009 at 4:24 PM
JFEHR86
I have the exact same problem with my eagle summit. It is extremely frustrating and I cannot find a solution! If you are able to fix it please let me know!!!
Jun 13, 2009 at 1:12 PM
DOCFIXIT
  • 18,828 POSTS
Has anyone tried to pull codes ? if not that would be the first thing to try
Jun 13, 2009 at 1:30 PM
