Engine Mechanical problem
1992 Eagle Summit 4 cyl Manual
Hello, I have a '92 Eagle Summit 1.5L and am planning to replace the head gasket to (hopefully) fix a pretty bad oil leak. The only part of this I haven't been able to fully grasp is the procedure relating to timing. I have been gathering bits here and there such as finding TDC, marking the timing belt, and not letting the camshaft rotate after removing the belt, etc. Could someone please detail this part of the procedure from start to finish, including how to secure the camshaft from moving? Obviously I am an amateur and I understand this is a pretty involved procedure, but I don't have a lot invested in this vehicle (it was going to get junked anyways) and I'd like to use this as a learning experience. I have the repair manual but it does not detail the timing procedure to the level that I need.
Thanks for the help
Thanks for the help
May 6, 2009 at 2:17 PM
