1992 Eagle Summit Changed engine, oxygen sensor problem
1992 EAGLE SUMMIT
220,000 MILES • 4 CYL • AWD • AUTOMATIC
ACHAGOOSEE
Mechanic dropped a 1.8 L. 1994 Eagle Summit engine from an automatic FWD, into a 1992 Summit AWD replacing a 2.4 L. failing engine. Everything OK except oxygen sensor, reads OK in shop but reads zero on highway. Repaced 3 times, relocated sensor, still the same. Ideas??
Apr 7, 2008 at 9:28 AM
2CARPRO JACK
  • 11,533 POSTS
Have you compared the sensors from each engine to see if there is a difference? Might be time for a pin to pin wiring check with a meter to be sure the wiring is good.
Apr 9, 2008 at 7:42 AM
