1992 Eagle Summit
1992 EAGLE SUMMIT
DOEBOY
Transmission problem
1992 Eagle Summit 4 cyl Front Wheel Drive Automatic
1st and 2nd gear do not engade but drive and revers do
Aug 29, 2009 at 11:13 AM
CH112063
  • 1,320 POSTS
When your auto trans is weak or loses pressure reverse goes first because it requires more pressure. The shift linkage or cable or valve body may be bad. If you never use them, you don't have to be concerned. If you are worried, have it looked at. I would have it repaired, just for safety reasons. Your welcome. Bye
Sep 17, 2009 at 4:30 PM
