1991 Eagle Summit starter location
1991 EAGLE SUMMIT
EAGLESUMMIT91'
Engine Mechanical problem
1991 Eagle Summit 4 cyl Front Wheel Drive Manual
i cannot find the starter on my summit. If possible i would like to know the location and any tips that could make it easier
Mar 21, 2010 at 3:20 PM
To locate the starter follow the battery positive cable it will take you straight to it
Disconnect battery ground cable.
On models w/1.5L engines, remove air cleaner and intake manifold stay, as needed, to gain access to starter.
Disconnect starter wiring.
Remove starter mounting bolts, then remove starter motor.
Reverse procedure to install.
Mar 21, 2010 at 4:27 PM
