Dying Truck
1980 CHEVROLET CUSTOM DELUXE
150,000 MILES • 4.8L • 6 CYL • 2WD • MANUAL
ROBSHANDYMANSERVICE
The truck will start and run just fine when it is in neutral, but as soon as I put it into gear and start to let off the clutch it sputters and dies, but if I let off the gas and push the clutch in it will stay running. This is my only transportation, and I need to find out what is wrong with it.
Mar 4, 2016 at 9:31 AM
HMAC300
  • 48,601 POSTS
check for a carburetor problem. It probably needs to be overhauled due to today's fuel. Also, check for a vacuum leak, assuming everything else is good.
Mar 4, 2016 at 12:12 PM
