intake manifold leak
2005 FORD FOCUS
133,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
ONEMOBILEONE
  • 5 POSTS
I have change intake gasket, multiple vacuum lines, even those that did not appear cracked or broken. I have also changed out the intake idle control valve, map sensor signal was stuck at 1.35 volts on the return wire, a solid 5 volts on the supply side, new idle air control motor, cleaned throttle body. It still will stall on a hot engine restart (running temperature) and give me a dtc code of P2004.
Aug 12, 2016 at 4:22 PM
SATURNTECH9
  • 30,869 POSTS
I see the number one fix is intake runner control solenoid valve.
Aug 12, 2016 at 8:05 PM
ONEMOBILEONE
  • 5 POSTS
Maybe, but that did not fix it.
Aug 13, 2016 at 8:44 AM
ONEMOBILEONE
  • 5 POSTS
I thought i had nailed it when I tested the map sensor and it failed, then removed it and it was full of gunk. so I changed it out tested it all good the car got to running temperature then I turned off the engine went to restart and it started and stalled and then started. at that point is when the hard code reappeared.
Aug 13, 2016 at 9:00 AM
SATURNTECH9
  • 30,869 POSTS
Have you checked for blocked or lined vacuum lines to the solenoid?
Aug 14, 2016 at 4:23 PM
SATURNTECH9
  • 30,869 POSTS
Blocked or kinked I mean?
Aug 14, 2016 at 4:24 PM
ONEMOBILEONE
  • 5 POSTS
I have replaced all vacuum lines with new vacuum lines none are kinked
Aug 17, 2016 at 12:35 PM
Can you remove the actuator and see if the can move the flap shaft by hand? Maybe it is stuck
Best, Ken
Aug 18, 2016 at 11:54 AM
ONEMOBILEONE
  • 5 POSTS
Thanks Ken...when I changed the manifold gasket I painstakingly clean each ports butterfly valve to make sure everything was moving freely also checked the vacuum actuator ...applied vacuum to it and it also moved freely...
At this point I'm looking at the pcv valve it seems week to me .... I would just pinch off the hose to it to test it but there's just not enough room behind the manifold to leave a clamp on it ... I hate throwing parts at a car with out testing it ...It's not the way I was taught. Have you ever had a pcv valve throw a code 2004?
Aug 19, 2016 at 12:18 PM
SATURNTECH9
  • 30,869 POSTS
If it was leaking vacuum it could.
Aug 19, 2016 at 8:12 PM
