I just have the vehicle listed above and it says invalid region when I put a DVD in it. How do I fix this?!?
Feb 3, 2022 at 6:51 PM
SQM
CERTIFIED EXPERT
If you are able to enter the settings, you might be able to change the region (1-6).
You might need to download a DVD ripping program, this can convert the region locked DVDs to region free. One of the programs is available called Winx DVD ripper.
If this is a factory equipped DVD player, the dealer should be able to unlock it.
Thank you.
Feb 3, 2022 at 9:48 PM
SKYLARR2902
MEMBER
Thank you. I’m going to call the dealer today because there are a few other issues.
Feb 4, 2022 at 4:07 AM
SQM
CERTIFIED EXPERT
You are welcome. Let me know how this issue turns out.
Feb 4, 2022 at 6:04 AM
SKYLARR2902
MEMBER
So, the dealer has no idea how to fix it. They had to call tech support and are basically waiting to hear back.
Feb 5, 2022 at 6:29 PM
SQM
CERTIFIED EXPERT
Interesting, usually on issues like this they can access the setting and modify as necessary.
Did they give you a timeline of how long before they will hear back?
Unless the tech support is in Japan (Nissan factory), it should not take too long.
Feb 5, 2022 at 6:32 PM
SKYLARR2902
MEMBER
I took it on Friday. I told them I would check back on Monday. He said he hoped he would hear back by then.
Feb 5, 2022 at 6:45 PM
SQM
CERTIFIED EXPERT
Got it. Let me know what you they and if they are able to resolve this.
Feb 5, 2022 at 7:04 PM
SKYLARR2902
MEMBER
I definitely will!
Feb 5, 2022 at 7:08 PM
SQM
CERTIFIED EXPERT
Sounds good!
Feb 5, 2022 at 7:16 PM
SKYLARR2902
MEMBER
Basically Nissan has no idea. They just called me.
Feb 8, 2022 at 5:16 AM
SQM
CERTIFIED EXPERT
That is terrible.
I will do some research and see if there is an easy solution.
One thing you can try is to call some of your local automotive audio/video stores that do sound systems and other accessories. They might be able to help.
