Welcome to 2CarPros.
Only use Honda's recommend ATF (Honda DW-1 ATF).
Here are the directions for servicing the transmission:
2014 Honda Fit EV ELE-Electric Engine
ATF Replacement
Vehicle Electric Drive Systems Transmission Transmission Fluid - Electric Drive Service and Repair Procedures ATF Replacement
ATF REPLACEMENT
ATF Replacement
Drain
1. Vehicle - Lift
1.
Raise the vehicle on a lift, and make sure it is securely supported.
2. Splash Shield - Remove
1.
Remove the splash shield (CLICK HERE).
3. ATF - Drain
pic 1
pic 2
1.
Remove the filler plug (A) and the sealing washer (B).
2.
Remove the drain plug (C) and the sealing washer (D) of the gear box side, remove the drain plug (E) and the sealing washer (F) of the motor side, and drain the ATF.
NOTE: Remove metal particles from the magnetic surface of the drain plug.
3.
Install the drain plugs of the gear box side and the motor side using new sealing washers.
Refill
1. ATF - Refill
pic 3
1.
Refill the gear box with the recommended fluid to the proper level (A). Always use Honda ATF DW-1 Automatic Transmission Fluid (ATF).
NOTE:
Using a non-Honda ATF can affect durability performance and the cooling performance of the gear box.
Keep all foreign particles out of the gear box.
Automatic Transmission Fluid Capacity:
1.1 L (1.2 US qt) at fluid change
1.2 L (1.3 US qt) at motor/gear box assembly replacement
2.
Install the filler plug (B) using a new sealing washer (C).
2. Splash Shield - Install
1.
Install the splash shield (CLICK HERE).
__________________-
Let me know if this helps.
Aug 23, 2019 at 12:12 PM
