I have the manual dual climate control with the two vertical sliders to control temp. I noticed a couple weeks ago that the passenger side vents would be blow hot air despite the temp setting at full cold. By moving the passenger side temp control up and down, changing the temperature, I am eventually able to get it to blow cold air again. But eventually, after a couple minutes it will go back to blowing hot.
Do I need to replace the blend door actuator, the climate control panel in the dash, or is it something else?
Advice please. Thank you in advance!
Aug 13, 2014 at 12:25 PM
