What do these codes mean, P22AD00O2, C123702, B136700, B168816, B111216, and B168787?
2018 HYUNDAI TUCSON
56,000 MILES • 2.0L • 4WD • AUTOMATIC
DAN ONDO
  • 9 POSTS
Hello, I have some errors code I would like someone to explain to me please and tell me what to do to fix the issues:
ENG
- P22AD00O2 Sensor Positive Current Control Circuit High (Bank 1 Sensor 2)
ABS/VDC
- C123702 Pressure sensor
AB
- B136700 Front passenger pretensioner resistance too high
A/C
- B168816 Cluster Ionizer Fault
OCS
- B111216 Low ignition voltage
- B168787 Airbag calculator communication error
Thank you very much for your time!
Jan 11, 2024 at 9:32 AM
Can I ask if all of these codes came up at once? If not, please start a new question for each code as we only handle one problem per thread. If they came up all at once I would try a hard system reboot or the software needs to be updated.
Here is a guide to help with the reboot:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Because these codes are different systems but still networked through the CAN I am leaning toward the software update. Please check all fuses in the car before we begin the repairs. Please go over this guide and get back to us.
Jan 11, 2024 at 11:42 AM
DAN ONDO
  • 9 POSTS
No, they didn’t come up at once. I first had the ABS and airbag codes. Now I have the engine error code for the sensor.
I will check the fuse and start a thread for each code.
Thanks
Jan 11, 2024 at 12:45 PM
Sounds good, if all the codes came up at once then we would have something in the CAN or computer issue.
Jan 13, 2024 at 9:41 AM
