Okay. Did the code return? These systems are monitored pretty closely so if the code or a different code didn't pop up, I would not replace any more of these. The issue could be related to this system but again, if no codes, the PCM is seeing what it needs out of these phasers.
I think at this point, let's get a recording of the "jumping" and the noise if possible. Clearly 2 videos is fine.
At this point I am not sure they are all related but they very well could be so let's work through this step by step. Starting with any codes and then recordings so we can get on the same page. Thanks
Mar 25, 2020 at 10:15 AM
