Chrysler deleted SB 18-079-16 from there files and I cannot find it. So they came out with a new bulletin that includes a new trouble code with the running rough condition. The symptoms is running rough and a warranty enhancement for a software upgrade for this condition. You will need to call Chrysler to see if it applies to your vehicle. Here is the bulletin and hope the info helps:
2013 Dodge Avenger
L4-2.4L
Flash: Power-train Diagnostic and System Enhancements
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Technical Service Bulletins Flash: Power-train Diagnostic and System Enhancements
FLASH: POWER-TRAIN DIAGNOSTIC AND SYSTEM ENHANCEMENTS
NUMBER:
18-058-17
GROUP:
18 - Vehicle Performance
DATE:
June 14, 2017
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 18-079-16, DATED JULY 18, 2016, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE A NEW DIAGNOSTIC TROUBLE CODE (DTC) FOR 2014 SALES CODE ED3, LOP AND UPDATED FAILURE CODE STATEMENT.
FOR HELP WITH USING wiTECH FOR ECU FLASH REPROGRAMMING, CLICK ON THE APPLICATION’S “HELP” TAB.
THE wiTECH SOFTWARE IS REQUIRED TO BE AT THE LATEST RELEASE BEFORE PERFORMING THIS PROCEDURE.
SUBJECT:
OVERVIEW:
This bulletin involves reprogramming the Power-train Control Module (PCM) with the latest available software.
MODELS:2013 - 2014(JS)Chrysler 200
Dodge Avenger
NOTE: This bulletin applies to vehicles equipped with a 2.4L I4 DOHC 16V Dual VVT Engine (Sales Code ED3), and a 6-Speed automatic transmission (Sales Code DG2).
NOTE: This bulletin applies to vehicles equipped with a 2.4L I4 PZEV 16V Dual VVT Engine(Sales Code EDG) equipped with a 6-Speed automatic transmission (Sales Code DG2) or equipped with a 4-Speed Automatic VLP Transmission (Sales Code DFF).
SYMPTOM/CONDITION:
**A small number of customers may experience a Malfunction Indicator Lamp (MIL) illumination. Upon further investigation the technician may find the following DTC.
P0335 - Crankshaft Position Sensor Circuit (2014 MY Sales Code ED3).**
In addition, customers may experience any of the following:
Rough idle (Sales Code EDG).A Transmission Tip-In bump (Sales Code EDG).Hard to start in cold ambient temps. (Sales Code EDG).Engine idle cycling on cold start in gear.Slight engine surge driving at highway speeds.DIAGNOSIS:
Using a Scan Tool (wiTECH) with the appropriate Diagnostic Procedures available in TechCONNECT, verify all related systems are functioning as designed. If DTCs are present, record them on the repair order and repair as necessary before proceeding further with this bulletin.
For all other customers that describe the symptom/condition, or if the technician finds any of the DTCs perform the Repair Procedure.
REPAIR PROCEDURE:
NOTE: Install a battery charger to ensure battery voltage does not drop below 13.2 volts. Do not allow the charging voltage to climb above 13.5 volts during the flash process.
NOTE: If this flash process is interrupted/aborted, the flash should be restarted.
Reprogram the PCM with the latest software. Detailed instructions for flashing control modules using the wiTECH Diagnostic Application are available by selecting the application’s "HELP" tab.Clear any DTCs that may have been set in any module due to reprogramming. The wiTECH application will automatically present all DTCs after the flash and allow them to be cleared.
Dec 17, 2019 at 9:58 PM
