dtc 2274 02 sensor bank 1 sensor 3 stuck on lean
2003 FORD FOCUS
80,000 MILES • 2.3L • 4 CYL • FWD • AUTOMATIC
RANDY SHARP
  • 165 POSTS
This problem with this car has been going on now for couple of years, and I have been neglecting it because it hasn't had a big difference on it running but cutting out once in a while. But now I tried to get it a smog today and I even turned off the check engine light and I guess they have a way now that they know a person resets there computer with out fixing the trouble code, it worked a couple of years ago, any way now I need to find the problem now. Does anyone know where I should start?Thanks
Oct 8, 2015 at 11:35 PM
MHPAUTOS
  • 31,937 POSTS
So many things can cause a check light to come on, I do need a code from the ecu, there may be one stored so go get a scan and re post what they find re codes, they should be able to look at the history to see deleted codes as well.
Oct 9, 2015 at 12:00 AM
RANDY SHARP
  • 165 POSTS
Yes the code is 2274 that is what comes up on my scanner
Oct 9, 2015 at 8:37 AM
MHPAUTOS
  • 31,937 POSTS
Two things I would consider are faulty O2 sensor, this can be checked with a live data read to see if the voltages are changing and look for any air leaks in the exhaust and vacuum leaks in the engine, start here,
Oct 13, 2015 at 2:19 AM
