Dtsc light and warning message on, yellow brake light on, ABS light is not on. I checked the codes, they attached. If you delete them, they will go off and you can start the car and drive, but they come back after a few. I checked wheel sensors on scanner, and they all are working fine. Hard to differentiate whether it's an issue with the clock spring or abs control module and am not sure if the ABS control module is the same as the dsc module.
Sep 15, 2024 at 4:29 PM
