Drl replacement
2017 JEEP COMPASS
60 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
HEXKINIMI
Need to replace the stock DRL bulbs with brighter ones. I need to know how to replace and also also know the exact size of led to replace them.
Nov 22, 2017 at 11:30 PM
STEVE W.
  • 15,113 POSTS
The DRL's on that vehicle are the high beam lamps turned on with a pulse width modulated signal to reduce the light output. They are designed to be low output. LED's will not work to replace them as the PWM signal will destroy the LED driver circuits. Also, because that vehicle drives the headlights through the TIPM module any real load increase from higher wattage lights will likely burn the driver circuits in the TIPM module out as well. Just one of the issues with modern vehicles.
Nov 23, 2017 at 6:34 AM
