I have new body style extended cab 4WD Silverado 2500HD and the DRL lights are not working. Low beams are fine and come on and off automatically.
The electrical diagram I have shows DRL relay in printed ckt board under engine compartment fuse box. Is that correct?
All fuses okay and I have tried a used fuse box. No change in symptoms and truck ran fine with different fuse box.
I seem to be down to wiring from BCM, BCM, or input to BCM? I see the BCM inputs as park brake on, hdlp on and ignition on? Not sure if light sensor plays a roll and if it does can it work in the auto on function and not the DRL.
A lot of questions I appreciate any help. Thanks.
Nov 22, 2019 at 11:34 AM
