Driveshaft/transmission
2004 HOLDEN COMMODORE
200,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
RUSS VANDERWERF
In reverse and only in reverse the car makes a grinding sound. It also feels like it’s stuck and when you accelerate it’s very laboured and feels like your pushing something. The noise sounds like bearings and I thought maybe centre bearing of tail shaft?
Thankyou
Apr 28, 2020 at 5:38 AM
If you have a carrier bearing between two drive shafts, check to make sure nothing is damaged. Also, have a helper slowly move backwards while you check to see if it is binding.
Let me know,
Apr 30, 2020 at 9:19 PM
