Okay, there is no service procedure for this constant velocity joint.
Replace the propeller shaft half if any of the following occur:
^ Important: The constant velocity (CV) joint assembly is not serviceable. If the dust boot is torn or the joint is worn or damaged, replace the propeller shaft as an assembly.
Inspect the constant velocity (CV) joint boot for rips or cracks.
^ Rotate the constant velocity (CV) joint to inspect for binding.
^ Inspect the constant velocity (CV) joint for grease or oil leakage.
Apr 13, 2019 at 5:30 PM
