Drives and will not start
2013 VOLKSWAGEN CC
155,000 MILES • 2.0L • V6 • TURBO • 2WD • AUTOMATIC
HEATHER LILLY
drive about 30-45 minutes and then idle for about 5 minutes it shuts off, immediately when restart until a few hours later and starts first diagnostic scan no codes and second diagnostic.
AutoZone Diagnostic Codes
01200-011 ABS Valve Voltage Supply - Open Circuit
01542-008 Rotation Rate Sensor -G202 - Implausible Signal
Secondary diagnostic codes:
18036-000 Powertrain data bus: Missing message from Steering angle sensor
18275-000 Powertrain data bus: Missing message from Steering wheel (J527)
DASH LIGHTS:
Tire pressure light - been on since I bought it recently started flashing at me
Stability Control Fault - said this when it shut off after no codes came on diagnostic
ESC light - comes on now after driving about 5 min
Car cuts off sometimes when turning right
* Sometimes it feels like the car is swaying, brakes start making grinding and loud thumping noise in back tires.
Battery tested and is good, battery connections are good, haven't found any blown fuses.
Apr 11, 2022 at 8:51 PM
Have you checked the rear brakes? Also, let's focus on the stalling issue and delayed restart.
What I need you to do is this. When the engine won't start, I need you to check if there is spark to the plugs and fuel to the engine. One is likely missing. By doing the following, it will narrow things down to a specific circuit that is failing.
First, when it won't start, see if it starts for a few seconds and then stalls if you use starting fluid. If it does, then we know it is fuel related. If there is no change, we need to check for ignition spark.
Here is a link that explains how this is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know the results.
Apr 12, 2022 at 8:31 PM
