drivers side seat heater not working, light turns on sometimes and does not heat
2007 INFINITI M35
74,000 MILES
MY06INFINITIM35
hello, I have been researching this, and have not found a fix, my drivers side seat heater is faulty sometimes it works some times the light comes on it just started happing a few weeks ago. how do I fix this?
Nov 8, 2013 at 10:25 PM
HMAC300
  • 48,601 POSTS
if it's a sedan or coupe they are alittle different. about all you can do is see if it's getting power the orange wire to dseat is high an dgray is low. if it gets power then it's a heater problem ifnot then look for a wiring issue. if you can't find the orange or gray wire then it's lt green or lt blue or gray or brown on otherwire.
Nov 9, 2013 at 8:25 AM
MY06INFINITIM35
If it's a sedan or coupe they are alittle different. about all you can do is see if it's getting power the orange wire to dseat is high an dgray is low. if it gets power then it's a heater problem ifnot then look for a wiring issue. if you can't find the orange or gray wire then it's lt green or lt blue or gray or brown on otherwire.
its a four door sedan, where are these wires located? is there a link or a video that shows location of what your talking about?
Nov 9, 2013 at 12:12 PM
HMAC300
  • 48,601 POSTS
the wires are under the seat and no I don't think there is a video unless you check online
Nov 9, 2013 at 12:55 PM
