After replacing the driver's side rear window motor does something need to be reset in order for it to work? The window is stuck in the down position and the dealer wanted to charge almost $700 to fix it. I ordered a motor. When I plugged it and pushed the window switch the gear didn't turn. Could it be the wiring or something else? Thank you,
Sep 19, 2013 at 8:02 AM
